show flowmon group template
show flowmon group group_name template detail
Description
Displays Flow Monitor group template information.
Syntax Description
group Specifies the Flow Monitor group.
group_name Specifies the assigned name of the Flow Monitor group. Range is 32 characters.
template Specifies to show template information for the specified group.
detail Specifies to show all information associated with the specified group.
Default
N/A.
Usage Guidelines
The complete template name is shown with the template key portion name.
When detail is entered, the Element IDs are shown in text form.
The following command shows template information for the group 'max-flow-age':
# show flowmon group max-flow-age template
This command was first available in ExtremeXOS 32.2.
Platform Availability
This command is available on ExtremeSwitching 5420, 5520, and 5720 series switches.
